What kind of Demolition cassette hub is this.
6/17/2017 6:40 AM
So I'm just looking on ebay and I saw the Demolition cassette hub and I wanted to know what kind hub this is so does anybody know what kind of Demolition hub it is like does have a name and what year it came out. Here are some pictures
6/17/2017 7:02 AM
a really old one, not sure of the name or if it even had one though but it's at least 10 years old cause my friend had one back in 2007
6/17/2017 7:33 AM
That will take a 13t cog, no smaller. But there might be a 9t driver out there that will fit it
6/17/2017 9:45 AM
Thanks so is a good idea to buy it it's cheap 39.99 plus shipping it looks like it doesn't with the driver or what Steve said it need a clog would a 25t work with this hub. Here are the information about the hub.
Demolition Rear Hub
Black Anodized
36 Holes
Sealed Bearing
14mm Axle
1lbs 9oz(720g)
110mm Spacing
6/17/2017 10:16 AM
Well. If it doesn't come with a cog, the smallest you'll be able to fit will be 13t. That would be really low gear with a 25t sprocket (really easy to pedal). To buy a 9t driver (to give you a better gear ratio) will probably cost another $30 or so.....
You could probably find a better, newer hub with a 9t 1 piece driver for less than it will cost you to get this to work with your current set up
6/17/2017 11:35 AM
Ok thanks I guess I will save my money to buy a newer hub.
6/17/2017 5:29 PM
36/13 is as low as you can get with a 2 PC driver, maybe 32/12? Definitely not 25/9
