What the fuck éclat?
10/18/2013 7:10 PM
So I followed the united video on how to switch Rhd to Lhd, but the thing is that when it's Lhd it skips basically every pedal then engages. Then I was like let me try Rhd again then and when it made it Rhd again it didn't skip at all and when I made it lhd it skips and then Rhd no skip lhd skip. So is it me doing it wrong or is my hub just fucked? If I am doing something wrong then what is it. Also I have a Éclat pulse cassette female
Bang Bang bmx
10/18/2013 7:19 PM
post pics
10/18/2013 7:21 PM
sundaybmxRR wrote:
post pics
Of what?
Bang Bang bmx
10/18/2013 7:44 PM
ThugLifeBmxRiderz wrote:
Of what?
Hub internals mayn.
10/18/2013 7:46 PM
BNC wrote:
Hub internals mayn.
This.
You might have something put together wrong
10/18/2013 7:54 PM
Their you go it's currently in lhd
Bang Bang bmx
10/18/2013 7:56 PM
Bang Bang bmx
10/18/2013 8:01 PM
Bang Bang bmx
10/18/2013 8:20 PM
did you switch the ratchet ring out too? it looks like it might still be in the RHD way
10/18/2013 8:31 PM
Edited Date/Time: 10/18/2013 8:35 PM
Nope... How do you do that? Sorry I'm a retard when it comes to hubs unless it's like super easy
Bang Bang bmx
10/18/2013 8:34 PM
Edited Date/Time: 10/18/2013 8:39 PM
what about the seal is it fucked up
10/18/2013 8:37 PM
Edited Date/Time: 10/18/2013 8:47 PM
I know for a fact I have the driver right...
Bang Bang bmx
10/18/2013 8:38 PM
See the C clip-like thing that goes around the hub and how it has 2 holes in the ends of them? need to get a spanner of some sort like this
and compress the ring so it pulls out of the hub, take the ratchet ring out since it should now be loose, and flip it, put it back in, and compress the ring again so it goes back into your hub and keeps the ratchet ring tight
I'd imagine needle nose pliers might work but only if they're skinny enough
10/18/2013 8:39 PM
"put the springs around the pawls"
wut.
he has the pawls/springs in correctly, his ratchet ring is just in wrong for LHD
10/18/2013 8:45 PM
wut.
yeah I forgot how I switched mine over..then I remembered. I was trippin' about the pawl and spring. that's why I edited my post I was wrong.
10/18/2013 8:47 PM
Edited Date/Time: 10/18/2013 8:49 PM
A stock United hub is not the same as an eclat hub...
I found a PDF of how to switch the Eclat Pulse drive side.
CLICK THIS LINK FOR INSTRUCTIONS
10/18/2013 8:54 PM
CLICK THIS ...more
We'll sorry I'm stupid and thanks also could I use 2 needles?
Bang Bang bmx
10/18/2013 9:15 PM
It might be pretty hard. I have c-clips on my driver bearing and non-drive side bearing and taking them out with regular pliers never worked.
10/19/2013 8:45 AM
CLICK THIS ...more
THIS.
Why are you saying "what the fuck eclat?" when you followed instructions from UNITED?
10/19/2013 12:41 PM
CLICK THIS ...more
Fondue wrote:
THIS.
It was to get people attention
Bang Bang bmx
10/19/2013 2:35 PM
CLICK THIS ...more
Fondue wrote:
THIS.
12/8/2013 6:09 PM
Sorry for the bump but.. I finally got to changing it and the PDF doesn't work.. What's next? I got the they out and now how do I get the engagement thing out?
Bang Bang bmx
12/8/2013 6:15 PM
Living that canadian thug life eh? maybe you put the pawls in upside down so they don't engage properly.
12/8/2013 6:48 PM
I took it out now and I'm ganna put it together and see what happeneds
Bang Bang bmx
12/8/2013 7:15 PM
The last thingy won't fit... It's bin like. 30 of me trying
Bang Bang bmx
12/8/2013 7:42 PM
Yo thuglife , if the LHD worked well , would you reccomend the hub? Is it good for grinding ?
12/8/2013 7:44 PM
I hammered it in.. And does this look right?
Bang Bang bmx
12/8/2013 7:47 PM
I still have to ride it.. When where you planning on getting it? I I'll ride it till then and then give you a review the day you plan on getting a new hub.. I've rode it RHD and it was pree awesome I didn't grind much.. But I have hub guards for it so I don't know how it would hold up to grinding without one.. But the hubs awesome you treat it good and it'll treat you good.
Bang Bang bmx
12/8/2013 9:34 PM
Well I put it together wrong and now when I move the driver the wheel doesn't move..
Bang Bang bmx
12/8/2013 9:59 PM
LockNut's on backwards, the little rubber piece goes against the driver & slips pver the very edge of the driver
