Ok I am getting a new rim for front I can either get a female axle or a male what's better for grinding
do you mean pegless grinding? Because with either axle, the hardware is inside the peg anyway.
Nope, 14mm female. It's the strongest design overall and easier to work on with pegs.
BSD Backstreet Pro
Shadow BTR
Gsport Ratchet
Stress BMX hub that should come out
There are others. I think Eclat makes one.
Tree Hubs are good too but get solid chromo bolts for it.
Those are the strongest.
eskimojay wrote:14 mm solid chromoly male axle
MaximusBikes wrote:Nope, 14mm female. It's the strongest design overall and easier to work on with pegs.
BSD Backstreet Pro
Shadow BTR
Gsport ...more
Nope. Pedal grinds. They are the best way to ensure your axles are fine.
BSD Backstreet Pro
Shadow BTR
Gsport ...moredave lawrence wrote:Nope. Pedal grinds. They are the best way to ensure your axles are fine.
pedal grinds with a grind plate on one side lol
skooter... dont be a pussy
BSD Backstreet Pro
Shadow BTR
Gsport ...more
He asked for a front hub. Get a G-sport simian female axle 20mm inner axle with 3/8s bolts.
Well, here's some actual advice.
If you are grinding, a front female axle will be much stronger than a 10mm (3/8") axle.
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
On the front a 10mm female is a lot stronger than a 10 mm male (they tend to bend really easily)
Its not a fuckin rim! A rim is that circle thing on the other end of those stick things coming out the centre.
NEW Bike check
Raw Clips Edit
EddiMundo wrote:Its not a fuckin rim! A rim is that circle thing on the other end of those stick things coming out the centre.
Zxzbmxteam wrote:Hey dumbass I'm lacing a hub up to my rim
You said you were getting a new rim and wanted to know what axle to get, hence you were referring either to the wheel and called it a rim, or youve found a rim with an axle.
NEW Bike check
Raw Clips Edit
