When I drop my bike, it is very noisy.
5/11/2013 11:49 AM
It is coming from somewhere in the front of my bike. I can't seem to figure out exactly where, though. It is almost like a loud rattle, but it goes away when im riding. Is it the headset? Do I have to tighten my front wheel?
5/11/2013 12:04 PM
It could be your headset, it could be your front hub.. It could be anything. Shake your front wheel side to side to see if theres any wobble. Do the same with your headset. The reason you don't hear anything while you're riding is because you're putting weight on the bike. Do you feel it when doing certain tricks?
Test your stuff out. Tighten things up, apply some lube. Ride it, drop it again see if you're still hearing it.
5/11/2013 12:08 PM
Take it apart and put it together, probably your chain though and my pedals rattled before they broke
5/11/2013 1:07 PM
Mines getting all loosy goosy. I stripped my fork bolt though and theyre 10 dollars. Whyyyyy? Jk, I know why
Anderson IN
5/11/2013 1:59 PM
Its the cones in your front hub, get a 17mm spanner and tighten them up smile happens to me all the time because i have unsealed bearings
5/11/2013 2:18 PM
Just take your whole front end apart, clean everything, regrease whatever needs to be, and put everything the way it should be.
5/11/2013 3:24 PM
Pedals would be my guess
My problem atleast
Refs:
ac~handley -les.cheek - the_bmxist -Skids007(x4) - Roqfan - jared42069 - Bmxnick2511
5/11/2013 3:58 PM
chain washers!!!!! mine did that forever. i couldent figure out what it was. its the little washers that go around the pins.
Old bike VVV
California Living
5/11/2013 4:40 PM
Could be really anything, just take it a part and rebuild it, this usually solves it, get everything nice and snug.
Check for cracks too you never know.
5/11/2013 4:45 PM
Dont drop it..........
5/11/2013 5:10 PM
cone nuts most likely. flip your bike upside down so the front wheel is facing up and then hit it from the side. if it makes noise, then it needs tightened
5/11/2013 8:36 PM
headset
front hub
chain
pegs
pedals
Save a tree
5/11/2013 9:01 PM
Chain washers? What's that? Show me pictures.
5/11/2013 11:40 PM
Right at the tip of the knifePhoto
Old bike VVV
California Living
5/12/2013 8:08 AM
Mine are loose as fuck, idk how to tighten them, or if I should get a new chain
5/12/2013 8:18 AM
you might have pebbles in your forks... that happened to me before
Refs:
Traded: tomdon
n-dür on facebook
5/12/2013 10:06 AM
They're called rollers.
OP, does anything on your bike feel wrong? Does it even make the noise when you hop?
5/12/2013 1:02 PM
my friend currently has a stone in his frame, mother fuka wont come out though...
NEW Bike check
Raw Clips Edit
