Which axle would be stronger?
9/15/2013 5:45 PM
20mm aluminum female axle or 15mm steel female axle? Steel is stronger than aluminum but the aluminum axle is bigger.
virginia beach ~ instagram: @_harru_ ~ 4pegz
9/15/2013 6:39 PM
Edited Date/Time: 9/15/2013 6:40 PM
you mean a 14 mm steel akle and is the 20mm on a Shadow btr cuz thats actually 17mm cromoly axle
MIDWEST MOTHER FUCKER
9/15/2013 7:05 PM
Steel. Aluminum can strip out and bend easier due to a lower tensile strength when comparing similar sizes.
If you run pegs, get a chromoly axle any chance you can.
9/15/2013 7:27 PM
If you run pegs, ...more
This.
9/15/2013 11:37 PM
True Female Axles don't take the weight of Grinding though, and if they're Helicoiled that's not a problem either.
9/16/2013 2:07 AM
Pretty sure the 20mm would be
