Like the regular design is too boring. Why doesn't these bike companies try new things
13 years old
13 years old
Why aren't there more phone designs? Like the regular design is too boring. Why doesn't these phone companies try new things?
IG
@curtis_cantbmxwell
Because Jesus Christ himself was reincarnated as odyssey product designer and there is no need for anything else because oddy forks are perfect in every way
/s
Why don't you try something new like shut the fuck up?
Weren't you spanked for staying on skype too long?
IG
@curtis_cantbmxwell
What are you expecting? Single legged forks? Crownless forks? The reason is because theres not much to be done with forks. Theres already alot of options for forks. Investment cast/traditional, regular/oversized crown, different offsets, hyrdroform, postweld, tapered/butted/straight, pegless, brakes/brakeless. If you go back a bit, theres even integrated pegs and peg bolts.
HardBMX_Tim wrote:What are you expecting? Single legged forks? Crownless forks? The reason is because theres not much to be done with forks. ...more
Not true. I was thinking forks with triangle legs cuz triangles are strong af. Also maybe a fork that where the top of the legs are shaped like 4 peice bars so like mtb forks a little bit but no shocks. Also maybe a fork that has notches on the steer tube so you can cut it easy to whatever size you need. Or a fork that is modern but has 14mm dropouts
13 years old
If you want drinks that are like mountain bike fork shape with no shocks you need to look into racing forks.
14mm option died alon with the 14mm front axle it's only used on shitty completes now.
Round tubing is quicker, easier and cheaper to make than triangle tubing
Neither are the forks you are describing. Thats just adding two more welds to break. Also wouldn't look so great to most and would add unnecessary weight. Its a weaker and heavier design, theres a reason companies dont use it.
As for triangle tubing- it would be expensive and ugly and wouldn't be any more superior than round-legged forks. Yes, a triangle is the hardest object to crush since it is the best at distributing force. However, this will not make for stronger welds or solve any of the common reasons for forks breaking.
HardBMX_Tim wrote:Neither are the forks you are describing. Thats just adding two more welds to break. Also wouldn't look so great to most and ...more
So that means 4pc bars are weaker, right?
FBM Pizza Beer Roast Machine
I've got old 14mm odyssey Classics on my wall. Now they are sick. Also a vandal hub shell and bearings but no axle. New to wack one up, but still wont have spokes for it
Krooked wrote:Racing forks are not built to take abuse
Collin_McClenahan wrote:So that means 4pc bars are weaker, right?
a properly done weld should be stronger than a bend
bmxsteve99 wrote:a properly done weld should be stronger than a bend
Depends on where the flex is on the bend and on the weld connection.
Technically our forks are already a triangle.
I see no advantage to two piece fork legs.
I'm not a fucking ref, don't list me.
Also, I could definitely see three piece (4 if you count the steerer tube) fork being stronger, but it would definitely be heavier. Odyssey forks are already strong enough while still being under 2 lbs. And obviously everything else is shit.
And Tim, if you pull the fork legs in on the right two designs, it will look much better. You drew them further apart to make the left seem stronger.
Xxohioanxx wrote:I'm not a fucking ref, don't list me.
Also, I could definitely see three piece (4 if you count the steerer tube) fork being ...more
Then how will they fit my Fat BMX tires?
Kidding. Didn't do that purposefully lol.
a triangle is not stronger than a circle. a triangle distributes weight over 3 points while a circle distributes it evenly. this is like sophomore level science class shit right here...
My Ride
My Other Ride
IG: evildeadhands
Krooked wrote:Not true. I was thinking forks with triangle legs cuz triangles are strong af. Also maybe a fork that where the top of the ...more
ironmaiden666 wrote:a triangle is not stronger than a circle. a triangle distributes weight over 3 points while a circle distributes it evenly. ...more
Im in sophomore science class rn chill
13 years old
now you're prepared. if you need homework help you're at the right place.
My Ride
My Other Ride
IG: evildeadhands
