Would this sprocket fit?
10/11/2017 3:00 PM
So I wanna get this sprocket but I don’t know if it will fit. My cranks are the ones with 2 bolts connecting them to the sprocket.
An Indian on a small bike
10/11/2017 3:14 PM
yes it should fit just make sue you use the right spacer.
Hmmm
10/11/2017 3:19 PM
So you probably have a 19mm spindle. Make sure you get a 19mm top hat.
10/11/2017 6:10 PM
Edited Date/Time: 10/11/2017 6:10 PM
New sprockets come with the spacers a lot of times to make it fit 19mm spindles and are pre-sized to fit 22mm with no adapters.
The one you pictured appears to have a spacer included just by looking at the center. You can see a second ring about 3mm thick.
10/12/2017 11:26 AM
Thanks for that guys. So the sprocket will come with an adapter for the spindle. What about the other bolt holding the crank onto the sprocket? Does the Kobra sprocket have a big enough hole for it?
10/12/2017 12:24 PM
Edited Date/Time: 10/12/2017 8:11 PM
Ved_goswami wrote:
Thanks for that guys. So the sprocket will come with an adapter for the spindle. What about the other bolt holding the crank ...more
The hole is standardized unless stated otherwise. The only time you would have complications on that front would be anything smaller than 23t would be considered "Nano" drive as opposed to the "Micro" drive that is pretty standard these days. All that means is your crankset would have to have the threaded attachment point closer to the spindle since the circumfrence of a sub 23t is too small to use the same hole and have it not interfere with the teeth or just plain not fit. Some cranksets have both holes threaded for micro and nano drive. Most stock and tons of aftermarket cranksets will not have both though, so be sure and check. Also, if it were a different design like spline drive or odysseys design, it would clearly state what its compatibility would be and visually will be pretty different.
10/12/2017 8:12 PM
Here is an example of the 2 hole cranksets that allow you to run both types.Photo
10/13/2017 12:17 AM
Will you also be getting a new chain? Some people say to replace chains when getting a new sprocket. You may need a chain breaker tool.
10/16/2017 11:50 AM
elytron wrote:
Will you also be getting a new chain? Some people say to replace chains when getting a new sprocket. You may need a chain ...more
I’m not sure. Why is that?
10/16/2017 11:51 AM
I’ll have a check if mine look like any of them. Mine are just stock ones for a Hoffman bama
10/16/2017 4:53 PM
I believe an old/dirty worn out chain, wears the new sprocket a little quicker. May be the case, but someone correct me if I am wrong. Anyone else out there replace the two at the same time?
10/16/2017 4:57 PM
elytron wrote:
I believe an old/dirty worn out chain, wears the new sprocket a little quicker. May be the case, but someone correct me if I ...more
I have been getting new chains with new sprockets. It does wear things out faster, you are correct.
10/16/2017 5:09 PM
A chain stretches over time. As it stretches, it wears your sprockets (especially aluminum) to that same stretch. So by changing your sprockets with the chain, your are starting fresh with everything.
10/16/2017 5:16 PM
Mishinn is correct. Also get a beefy chain with thick links and such so the chain has minimal stretch.
I dont trust thin cheap chains anymore.
10/17/2017 9:53 AM
My cranks have the second hole thing welded on to it. Doesn’t look like any of those in the pic
10/17/2017 9:54 AM
Here’s a pic Photo
10/17/2017 10:05 AM
That's the drive hole. Without that screw, you'll crank but the sprocket won't turn with the cranks. It's the way it's been done for decades so you should be fine.
10/17/2017 10:10 AM
Listen.... it's fine. It doesn't have to look just like the other picture. They make sprockets to fit that approx. setup. Which is the setup that has been used for decades.
10/17/2017 10:13 AM
Edited Date/Time: 10/17/2017 10:14 AM
Your cranks appear to be standard, 23t and up, bolt drive compatibility.
10/17/2017 10:51 AM
You don't always have to replace a chain and sprocket at the same time. You only need to replace either when they are worn. Bmx parts wear at a completely different rate to road or mtb parts. You're more likely to wear a driver quickly than a sprocket as it has so many more rotations.
If you get a new sprocket and the chain makes a load of noise then you know it's time to get a new chain. If you get a new chain and the chain makes noise, chances are its the driver.
10/17/2017 2:43 PM
Mishinn_Control wrote:
Listen.... it's fine. It doesn't have to look just like the other picture. They make sprockets to fit that approx. setup. ...more
Oh okay thanks man. So I think I’ll go ahead and get that sprocket
10/17/2017 2:57 PM
You should just get a new cheap chain anyway. It's like $10, and everything will run smother, and wear in properly.
10/17/2017 3:04 PM
Get a couple spacers too. The sprocket will probably be a little thicker/thinner than your current one so you'll need space it so your crank/chainstay distance is the same on both sides.
10/17/2017 3:14 PM
Dont go cheap on a chain, you can get a 5-10 dollar chain that will work but not only will it flex when you're pedaling but it will prematurely stretch and possibly snap at the worst time. Imo, you dhould get something you will trust.
Odyssey hollow and standard keychain, shadow conspiracy supreme, fly tractor chain etc.
10/17/2017 6:33 PM
I dont trust thin ...more
With the exception of half-links, chains don't actually stretch. The pins and rollers wear, thereby increasing the distance from one pin to another and thinning the rollers. This is what gives the illusion of stretch.
I do agree with the beefy chains though, I've had far too many long walks home after landing on my chain and breaking it.
10/17/2017 7:23 PM
p1p1092 wrote:
With the exception of half-links, chains don't actually stretch. The pins and rollers wear, thereby increasing the distance ...more
You know what, youre right, now that I think of it I only see wear on the pins where the inner links ride on them.
I was applying the half link stretch mentality to both types of chain.
