a hub question and crank arm grind question
11/12/2011 8:04 PM
1: When i crank and start going and then take my feet off ( say standing on the back pegs, but still going forward) the cranks spin i.e. ghost pedaling, why does is do this? I have a bicycle union v2 LHD hub and my homie said that there is some kind of seal on the inside of my hub that broke and if i pull it out it will be good. If it matters i run my chain very tight
in short: my cranks spin on their own
2: how the shit do you do crank arm grinds? i was trying them today and i was sliding for a little while but idk is it supposed to feel awkward as hell? and i've already seen then Trey Jones and The Jim C. vids so dont worry about posting them.
Ref(s):xBikeaholicx,SafetyFirst
11/12/2011 8:12 PM
my bike does the same thing. im pretty sure its normal. does it do it all the time? mine only does it when im goiing slow. if im hauling ass and take both feet off they usually stay where they are
SUNDAY OG
Sign by Danasoft - Get Your Sign
11/12/2011 8:13 PM
the same, but the opposite it does it when i go fast but not slow if not both
11/12/2011 8:15 PM
your pedals should not move when your feet are off the pedals. best thing to do would be to take apart the hub and clean and re grease it. check to see if anything else is broken too.
A bike is not a bike if it doesn't have air in the tires.
BSD Front Street Hub Review
Primo Mix Review
Why You WEAR a mouthguard!
Refs.
\BMX-1995/
11/12/2011 8:18 PM
every bike ive ever had has done that.
Boldly going nowhere.
BIKE CHECK.
11/12/2011 8:29 PM
your chain is too tight and your hub bearings may have a broken.
Bike check?
11/12/2011 10:48 PM
THIS
11/13/2011 12:08 AM
for the crank grinds the more sideways you are the cleaner it feels and looks...unless you fall over
