animal mtt tires?
12/28/2013 6:14 PM
are these good? they look meaty, but they only pump up to 75 psi. i usually run 90 psi.
so, which absorbs more impact and protects against pinch flats: a thicker tire tread or a higher psi?
This week's Sweet Shoutout goes to: biggybuggy!
12/28/2013 6:24 PM
Edited Date/Time: 12/28/2013 6:25 PM
Ive ran my MTTs @ 80 with no problems, so only ten less than what you would normally run, I'm sure you could run a bit more too and they'd be fine.
A lot of factors come into play with pinch flats, like rim walls, rim strip, psi, fat or thin tires, if you've got a decent wheelset tho you shouldn't really have any problems with getting pinch flats
I like these tires, but only for street tho, park & dirt tires need a higher psi in my opinion.
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
12/28/2013 6:30 PM
Soulrebelrastaman wrote:
Ive ran my MTTs @ 80 with no problems, so only ten less than what you would normally run, I'm sure you could run a bit more ...more
so if i ran em at 70 psi, would that be good for 8 ft roof drops?
12/28/2013 6:40 PM
I'd run them them at their psi max if i were you as they don't feel solid at 75 like some thinner tires would at that psi, but that's up to you tho really, just preference.
dangerous thing.
without it.
Os 94
Ms 01
Ns 12
12/28/2013 6:48 PM
I'd run them them at their psi max if i were you as they don't feel solid at 75 like some thinner tires would at that psi, but ...more
thanks for the help. i think i'm gonna go w/ the glh tires though
12/28/2013 7:25 PM
Edited Date/Time: 12/28/2013 7:25 PM
Can't go wrong with them, good choice.
dangerous thing.
without it.
Os 94
Ms 01
Ns 12
12/28/2013 8:27 PM
If these things even went to 100 PSI, they'd be like 2.5" or 2.6" in diameter.
12/28/2013 10:48 PM
Biggest tires made yo
Bang Bang bmx
