I crank down on my left foot, makes a click sound and I can feel it in my left foot. Cinema zx hub. Ran my wheel crooked on accident last ride. Discuss.
Your over thinking it ride it till it explodes.....bikes are made of metal with moving parts they make noises
This ^^^ f.it!
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
I bet it's in your crank if it's only when your left foot goes down, most likely due to your cranks shifting on the spindle.
take the arm off & grease the splines, then put it back on & if you have a pinch bolt, make sure to tighten that well also. Do the same thing to your other side too just to eliminate the chance of that doing the same thing, then try & see if it makes a noise again
sundaybmxRR wrote:I bet it's in your crank if it's only when your left foot goes down, most likely due to your cranks shifting on the spindle.
...more
Thanks!
I had a similar problem and it turned out to be my bottom bracket. It broke somehow and the inner ring (where the spindle sits?) would wobble like crazy.
the amount of times i feel a creek or pop or something from pedalling, and i think i know what it is, and im wrong is probs in the hundreds. tbh, its probably not what you think :L
NEW Bike check
Raw Clips Edit
Calling out Sundaybmxrr....... for being helpful as shit. Did exactly what he said to do, no click, just the sounds of spokes grinding on each other.
biggybuggy wrote:Calling out Sundaybmxrr....... for being helpful as shit. Did exactly what he said to do, no click, just the sounds of spokes ...more
Tension them up and they won't creak!
