bar end problems
1/4/2014 9:37 AM
so i have the Odyssey Par Ends and i need to take them out but they are stuck, any suggestions? and i tried taking the bolt/screw out but its still no help
1/4/2014 9:41 AM
Fold the end of your over so that you can get ahold of the full par end and pull it out. If that doesn't work, use a hammer and screw driver on the back side of it (where you folded your grip) to tap it out.
1/4/2014 9:49 AM
I don't know if this works with Par Ends, but with normal Bar ends that use a screw if you unscrew till the screw is nearly completely out and then tap it (not screw it) back in it will come out easily.
1/4/2014 10:13 AM
muscle
I'm gonna need bigger bars
1/4/2014 11:14 AM
Dynamite always works
1/4/2014 11:26 AM
yes but i might need to use the par end again...
1/4/2014 12:47 PM
They're pretty weird , keep screwing at them. It'll take 3 minutes but it should work.
If the screw came out , try screwing it back in and them back out. If that doesn't work , take a screwdriver and try to pry it out, or take a hammer and smash the end off if really necessary.
1/4/2014 1:02 PM
If you did what I said and had no luck, you might aswell drill it out.Photo
1/4/2014 3:14 PM
i got it stuck on my old bars, if ur really desperate take the bars but the par end on a vice grip and twist the bars to losen them then just rip em out
