bars
1/23/2016 7:58 AM
Anyone know of any ed black bars that are 9 rise or above that have a good clamping thing,my bar slip a lot I just want some beefy bars that won't slip
1/23/2016 10:59 AM
Pretty sure hoder highs come in trans black and are straight gauge so they're plenty strong enough. Not much upsweep though which put me off them
1/23/2016 12:11 PM
bsd giraffic
1/23/2016 12:20 PM
420bongblazer wrote:
bsd giraffic
This buddy has them and they're good
1/23/2016 12:29 PM
can't go wrong with BSD products. Literally never had a problem or heard of one.
1/23/2016 12:45 PM
So they have a good clamping thread that won't let my bars slip
1/23/2016 1:06 PM
Hello friend! Get a super beefy stem if yore worried about handlebar slip. I traded my old polished stem for s/m credence and ive never slipped once. I went 10 ft drop to bars and no movement.. Alternatively, my hi polish stem slipped evry bars i tried, do you tighten bolts in an X pattern. That is really important too for maximum grippage
1/23/2016 2:18 PM
Edited Date/Time: 1/23/2016 2:20 PM
Eh, the best clamping for your bars is going to come from your stem. While most issues with slipping bars are caused from user error, something that might help is choosing a stem that doesn't split the front plate in half so that there's more contact with the bars. Pretty much all bars have enough knurling to be clamped properly so buying new bars might be just throwing your money away unless you've really stripped them or really want different dimensions.
Make sure you torque each of the bolts down gradually and evenly. Personally I just eyeball it and make sure I give each bolt the same number of turns and never have problems with slipping bars. You'll see the stem clamp and the gap between the faceplate and the base of the stem shrink as you tighten each bolt so make sure every gap is the same distance.
1/23/2016 3:35 PM
Madera Mast stem! Clamps good and looks like a work of art compared to other stems. Also has many available sizes.
"STREET" all day, ere'day.
1/23/2016 5:41 PM
Get the new Eclat stem with the knurled faceplate and base , should help
1/24/2016 9:32 AM
Stems with a split face act the same as stems with a full face with internal machining. They actually grip a bit more.
But yeah, tighten your bolts the same amount in an X pattern and you should be good. Sand your bars and stem if you need to.
YOU AVIN A LAUGH M8?
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
The Trailest Bike On Vital
1/24/2016 9:33 AM
This will just lead to increased slipping. Aluminum is too soft for a design like that. The teeth will break apart, letting your bars slip way easier.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
1/24/2016 9:36 AM
You could not be more wrong, if torqued do properly the splined setup will be exponentially stronger.
