I am honestly a fan of my Odyssey Vandero2. 17mm Gsport axle and average sized bearings. Incredibly light also which is cool. Only downside is theres no chromoly hardware guards available for it!
My Primo N4FL was sweet. Flangeless definitely upped the stiffness since it redirected the way the bends are pulled on. 15mm axle and 6902 bearings which are very common in hubs and proven to be durable. Pre installed plastic guards that can be replaced with DG chromolys for any street hard-hitters.
Tree v3 is obviously a good option. Straight pull which makes the wheel SOO much stiffer due to NO BENDS!
Gsport Simian is an obvious one. Oversized everything and lifetime warranty. Strongest freestyle front hub available no doubt!
For rims there is a vast majority of choices you cant go wrong with. If youre looking to save some weight- Alienation Runaway Stay Strong, Felon, Malice or Gsport Birdcage. If youre looking for a generally nuke proof one and weight is no issue, Gsport Ribcage OR Alienation 7up. I strongly believe the 7up is stronger than the ribcage. It has SUPER beefy walls, 7000series aluminum, and a whopping 19.4oz! (Heavier than a Ribcage! Damn!)
