bottom bracket help!
8/26/2015 2:48 AM
i need a new bottom bracket and im not sure if there is a certain size i need or what...
this is the only information i have on my bottom bracket: New Salt Plus mid size BB, press fit, sealed bearing.
does this mean any mid size bottom bracket will fit? i see sizes from like 22m to 19mm that are named "mid".
any help would be great, thanks.
8/26/2015 5:07 AM
Mid is the outer diameter of the bearing, you also need your crank spindle size. I would bet your stock cranks are 19mm. Check the specs on your bike.
8/26/2015 8:36 AM
I;ve got the salt plus mid BB on my WTP... WTP bikes are so salty!
Yep, the inner diameter ( =crank size) is 19mm.
Recheck for yours first.
22mms are stronger but heavier. If you are not too aggressive go for a new 19mm one?
8/26/2015 2:52 PM
Recheck ...more
thanks for that dude! i cant find the crank size anywhere online but il have a look on the side of the cranks to see if it has the sizes.
