brake cable
10/24/2009 5:45 AM
i got a new brake cable (oddysee slic) and i took the cable out of the housing so i could slide this little piece off. now 1 string of the cable is coming apart from the rest should i just i just cut off that whole line?
I ride street. tongue
get amaon gift cards or money sent to your paypal for free! http://www.rebelbucks.com/?ref=yaya2893-0
10/24/2009 5:52 AM
is the string on the actual brake cable or on the housing (the part that covers the cable)?
10/24/2009 5:54 AM
the actual brake cable so wen i try and put it in the housing again the string gets all scrunched up
10/24/2009 6:00 AM
yeah you should trim it down, and then trim down the outer housing. if you leave it frayed the cable wont work good and it will just cause you more problems
10/24/2009 6:03 AM
k thx
10/24/2009 6:03 AM
so cut that whole line off?
10/24/2009 6:13 AM
cut the part off thats frayed, then trim down the outer housing to fit the length of the cable. the cable is going to be a little bit shorter now but it will work much better than if its all frayed. it happened to me before and i didnt do anything so the whole cable got like messed up so i had to get a new inner cable
10/24/2009 6:42 AM
same thing happend to me on same cable just pull it out to end and cut iit
Biggest troll.
