brake help
4/4/2009 11:17 AM
do you cut the little ball off the end of the brake cable when installing.
the ball on the opposite side of the lever that goes to the brake.
thanks.
we the people bike co.
4/4/2009 6:37 PM
bump.
so i got it all set up but i have a problem.
the lever wont return all the way back because the cable is too long.
when i tryed to fix it by pulling the wire out on the other side to make it tighter it didnt work.
the wire wont slide inside the casing anymore.
what do i do?
4/4/2009 6:38 PM
are your brake arms under tension
i have a 50" cable and mine goes back super fast
don't put your finger anywhere you wouldn't put your dick
cell# 518 682. 718.0.(only for parts)
refs
i ride fly, devyn, hattrckhcky, spikez5, blackout2010, 3514eclat, mikelee, brecher, TCbmx
4/4/2009 6:53 PM
no. when i tryed to pull the cable tight not the casing. it was only on the lever the other side was not atached to the hanger
4/4/2009 7:09 PM
tighthen the brake springs
WILBERT HERNANDEZ...
4/4/2009 7:12 PM
so the brakes are not hooked up? then they wont return as the lever aint spring loaded. i had to cut that lil ball off to get it thru my hanger and stuff. its there to keep the cable from fraying.
(\__/)
( .Y. )
(")v(")
09 Kink Transition...yes...i ride a tranny.
Im the CLIT commander of the sexy army.
4/4/2009 7:39 PM
i had to cut off the little ball thingy too.
and no but i had all the breaks set up but the lever wouldnt go all the way back because there was to much wire inbetween were the little cylinder goes in the lever and where the cable goes in.
i just dont know why i cant pull the wire. it would before but now its like the wire is suck to the wire cover thingy.
