Image and video hosting by TinyPic
they should
Team fatcats fer life
BIKE CHECK BELOW!
http://www.vitalbmx.com/forums/General-BMX-Talk,2/Updated-Bicycle-Check,811055
its not the tube, its the tire man.
the tire holds the tube in, so if the tire blows up, the tube goes with it
Ridin the world, one country at a time
QFT.
80 PSI is nothing--When you get to 150 PSI then you can start worrying.
Yes, I really live in Wyoming.
the tire holds the tube in, so if the tire blows up, the tube goes with itmontymitch wrote:
QFT.
not even. tubes dont matter when your dealing with psi. Its all the tire.
And wtf does QFT mean?
Custom printed tees and decals! 716-708-5264
BRAKELESS-BMX14 wrote:
they should
i agreeee
CANCER-AIDS0CANCER-AIDS-CANCER-AIDS-CANCER-AIDS-CANCER-AIDS-CANCER-AIDS
QFT.
80 PSI is nothing--When you get to 150 PSI then you can start worrying.agfracing wrote:
i beg to differ
QFT.
i agree
I run nothing but cheap ass tubes from walmart. Just go with the range on you tire give or take maybe 10 psi. They put those ratings on the tire because they tested what it takes to blow out, and it has to do with the rubber quality, thread count in the tire, and bead.
QFT: quoted for truth
The only reason you would worry about a tube over 150 PSI is because of the valve stem--it could fail. In other words, it's a non issue. Nobody makes tires that can handle 150.
