chain wont stay tight
1/9/2014 3:50 PM
yoo doods. so ill tighten my chain and my cranks will be in one position and my chain is super tight, but when i spin my cranks to another position my chain will be loose again. anybody know how to fix this? and yes, i tighten my axle nuts really tight so i know thats not the problem.
1/9/2014 3:55 PM
Get a new chain.....you can't fix it your chain is stretched .....mine does that to I usually don't give a shit until it snaps then replace it
1/9/2014 3:56 PM
I think it's just a loose spot or the sprocket is warped i have no clue but it depends on how loose it is. But if it isn't that loose don't worry about it.
1/9/2014 3:58 PM
your chain is either stretched or your sprocket is bent.
Old bike VVV
California Living
1/9/2014 3:58 PM
Chain tensioners work great for this issue, and their pretty cheap to pick up too, if that doesnt fix it though your chain is stretched and likely to snap soon.
1/9/2014 4:04 PM
http://www.odysseybmx.com/dailyword/2005/09/88-chain-tension/
check this, george talks about all kind of problems about tight and loose spots, and explains how to fix them.
1/9/2014 4:21 PM
i know the sprockets not bent, so the chains probably just stretched. thanks!
