couple of help questions Please give a hand.
7/20/2014 8:32 PM
Okay well I bought the new bonedeth porn cassette and it should be here in a few days.
I am relacing my front wheel aswell wich is a G-SPORT monkey laced to a G-Sport Ribcage in 48. the spare rim that I am using for the rear is a brand new Primo Hula hoop in 48H.
Now i am starting to wonder weather I should lace the hula hoop to the front or rear, like which one is stronger the hula hoop or the rib cage. (I don't mind at all about the weight of the hula hoop so please dont say "Well the Ribcage has the best strength to weight ratio")
These will both be laces with USA brand stainless spokes. Also I have desided to run brakes in the rear soon aswell if that could help.
7/20/2014 9:24 PM
I would go with the rib cage
7/20/2014 9:27 PM
All depends if you are front heavy or back heavy on your bike while your riding. I'd try and even the bike out as much as possible.
Or if one rim is chrome I'd use that as the rim for the brakes
7/20/2014 9:48 PM
Either one would be okay I'd think. They are both really strong rims. 48H rims take a while to lace and true haha I like them though
7/20/2014 9:53 PM
Gump wrote:
All depends if you are front heavy or back heavy on your bike while your riding. I'd try and even the bike out as much as ...more
this.
Personally though I'd go with the Ribcage in the rear just because I have no experience with the Hula-Hoop & it would give me peace of mind knowing my back wheel's super strong haha. Not saying the Primo isn't though, just saying I have no experience with it or knowing how they heard up other than hearing they're pretty damn strong.
7/20/2014 10:04 PM
okay they are both black rims. What one do you believe will how up better with brakes?
7/20/2014 10:14 PM
I THINK the Ribcage would be better for brakes due to its hard anodizing finish, that is if it wasn't rawed down/resprayed or something.
7/20/2014 10:14 PM
Not sure of the brake performance aspect. But I'd just try and even the weights up
7/20/2014 10:19 PM
Alright thanks guys. By the sounds of it the Rib is stronger so i'll lace that in the rear and the hula hoop in the front.
7/21/2014 2:51 AM
Sounds good!
7/21/2014 3:31 PM
6000 series grips better than 7000 series. The lower the number, the better grip aswell. Example, 6061 will grip better than both 6069 and 7005. Ofcourse this doesn't really matter unless your sidewall is raw. Gsport is hard anodized so the finish on it will last longer with brakes. Id do Rib in rear and Primo in front for this reason aswell as id rather have the heavier of the two in the front to balance the weight a little bit.
7/22/2014 5:42 AM
Edited Date/Time: 7/22/2014 5:43 AM
The two hula hoops I have run have been super solid, I rarely had to true them. It was an awesome rim. Super underrated in my opinion.
7/22/2014 3:35 PM
HardBMX_Tim wrote:
6000 series grips better than 7000 series. The lower the number, the better grip aswell. Example, 6061 will grip better than ...more
About the lower grade/formula material being grippier. Is that because it is softer this allowing the brakes to grip easier or having a slightly courser Finish? Interested about this.
Thank you
7/22/2014 3:41 PM
jamiespadina wrote:
About the lower grade/formula material being grippier. Is that because it is softer this allowing the brakes to grip easier or ...more
Not too sure, just going off personal experience. Most likely because the material is softer. But if both are anodized then they will grip extremely similar since the pads aren't gripping the aluminum, theyre gripping the finish.
7/22/2014 4:27 PM
HardBMX_Tim wrote:
Not too sure, just going off personal experience. Most likely because the material is softer. But if both are anodized then ...more
Alright thanks. And i decided to lace the G-Sport to the front with the g-sport monkey. Came to mind that there isn't going to be much clearance in the rear with the 2.25 GLH and seeing as the Ribcage has a wider profile than the Hula-hoop it would allow the tie to be wider. Also like the feel of a heavy rear end. But thank you a lot guys. you really helped a lot,
