crank slide help
7/25/2013 11:28 AM
I pretty much went face first into the floor yesterday so ya, i need help :/
Refs:
ac~handley -les.cheek - the_bmxist -Skids007(x4) - Roqfan - jared42069 - Bmxnick2511
7/25/2013 11:31 AM
hop on at a slight angle. its more of a pedal crook than a crank slide. mostly on pedal spindle. lean forward to keep your back end off the ground
7/25/2013 11:50 AM
tomdon wrote:
hop on at a slight angle. its more of a pedal crook than a crank slide. mostly on pedal spindle. lean forward to keep your ...more
Would it be ok if i tried to put the front peg on/actually do a pedal crook at first?
Refs:
7/25/2013 11:59 AM
Grind with your crank facing the back. I get the rail between the crank, bb, and pedal. Keep your weight over the bb
I ride for my papou.
Cats got 9 lives I got four.
7/25/2013 12:05 PM
I think your describing bb slides
Refs:
7/25/2013 12:07 PM
only advice ive had for those is to lean forward i only know one person that does them
Albes Is Rad!!!
YouTube
Instagram
Blood Life
7/25/2013 12:07 PM
No. Have the majority of the rail on your crankarm. But its okay if it slides ack and forth between the bb and pedal.
7/25/2013 12:32 PM
Try to land not too straight not too sideways.
Try it on flat rails better, basically what you want to do is land in between your crank and pedal, just right on the pedal boss.
Keep some pressure on it but not too much.
7/25/2013 2:22 PM
I don't see how that's a problem. Whatever helps you learn
