danscomp product info question
8/4/2013 9:26 PM
Edited Date/Time: 8/4/2013 9:31 PM
so on forks, you have forks with a crown race that needs to be installed and then "integrated" and then "integrated (campy spec).... so what is the difference between the two integrated styles, i mean is the non campy version just less specific for headsets, i mean cause i have an unsealed fsa pig standard headset and i just figure i could lay the bearing race over the non campy integrated style forks and do just fine with my headset.... would something like that work
because i want these forks https://www.danscomp.com/products-PARTS/353034/Mankind_Justice_Fork.html
My Youtube / RainBMX
My Insta / What_Is_Barspin
8/4/2013 9:32 PM
okay campy spec is 45/45 degree and the standard integrated is something else. most new headsets should work 45/45 check the description on your headset but should work alright anyway if you don't have 45/45
8/4/2013 9:36 PM
jamiespadina wrote:
okay campy spec is 45/45 degree and the standard integrated is something else. most new headsets should work 45/45 check the ...more
well mine is a loose ball headset which is this one http://www.danscomp.com/301054.php
and the race that comes with it, i was thinking to lay it over the integrated one (non campy)
8/4/2013 9:50 PM
Get a mechanik headset They will work with a fork that has a int race built in.Fudging headsets will work.......for a short time.Then destroy it's self.
8/4/2013 9:56 PM
bloghogs wrote:
Get a mechanik headset They will work with a fork that has a int race built in.Fudging headsets will work.......for a short ...more
they do not have it anymore
8/4/2013 10:57 PM
Edited Date/Time: 8/4/2013 10:57 PM
Campy standard (45/45) IS the 'standard'. A couple of frames used 36/45 but it was the minority and I doubt anyone does it anymore
Not a good idea to run looseball headset with integrated-race forks
8/4/2013 11:23 PM
jawn wrote:
Campy standard (45/45) IS the 'standard'. A couple of frames used 36/45 but it was the minority and I doubt anyone does it ...more
okay but what if i put on the separate bearing race that came with my headset over the integrated race
8/4/2013 11:27 PM
That's also a bad idea. It will be the very edge of a 90° corner pressed against a 45° ramp. Such a small surface area will not be able to bear the load it needs to
8/5/2013 12:47 AM
I would either get the headset I mentioned,or get a fork that doesnt have a built in integrated race.(if there are any anymore)
8/5/2013 1:02 AM
bloghogs wrote:
I would either get the headset I mentioned,or get a fork that doesnt have a built in integrated race.(if there are any ...more
well the fit blades have that option
8/5/2013 1:21 AM
Odyssey Dirts may still have the option too
8/5/2013 8:48 AM
dont they come with 14mm dropouts, or not anymore?
8/5/2013 12:08 PM
Order from empire instead. Shoot them an email and they will tell you what will work
