drive side hub gaurd
8/28/2016 9:33 AM
I'm having a really hard time finding a drive side hub gaurd for my bike. I have 3/8" bolts that screw into the female axle. It seems like everything im finding online is for a 14mm axle with studs. Do you guys have any suggestions?
8/28/2016 9:55 AM
It depends on the size of your axle, a lot are 14mm, so the hub guard should still fit. It replaces the cone nut on a lot of them. But some female axles are bigger than 14mm
8/28/2016 10:52 AM
8/28/2016 12:47 PM
After looking at the drive side of my bike it doesn't look like there is a cone nut, just a lock nut for the driver. I'm pretty lost trying to find a hub guard that will work.
8/28/2016 12:50 PM
G-Sport Uniguard
https://www.danscomp.com/products/512209/GSport_Uniguard_Rear_Hub_Guard.html
chromoly and comes in 3/8", plus it slides over the outside of your dropouts so no need to spread them. I like mine
8/28/2016 12:51 PM
GSport Uniguard will work and comes in 10mm. It just sits outside your frame.
Another option is something like the S&M Cymbal DS guard. This will sit on the 14 mm part of your axle, you will just need to add an adapter to the 10mm bolt so that it sits in your 14mm drop out properly. If you go this route, just make sure that everything lines up properly so it will tighten to the frame, and not just to the hub itself. This can happen if your adapter sticks out further than the frame dropouts.
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
8/28/2016 12:56 PM
I'm gonna go with the gsport unigaurd. Thanks for the help!!!!
8/31/2016 7:13 PM
Thanks for the help guys! Picked up the g sport Uni guard, and a guarded bsd sprocket!
8/31/2016 7:34 PM
[LINK TO IMAGE]Also picked up a bsd gaurded sprocket
8/31/2016 9:19 PM
Looks sweet!
