eastern frame
11/1/2015 8:02 PM
i am trying to figure out what kind of frame i have but its very difficult since noone can seem to help either.I believe i had measured it correctly the top tube seems to be 19' 1/2.
11/1/2015 8:25 PM
Email Eastern they'll tell you exactly. Pics of the BB would help.
Looks to be from around 2008-9 to me. It has welded gyro tabs but sealed everything else. It's most likely a complete one.
19.5 doesn't sound right, it's probably 20.5
11/1/2015 9:09 PM
Almost bet a ball it's 20.5
11/1/2015 9:13 PM
If it is a 19.5" it's likely a low level/entry bike.
What's the serial number? And is it a Spanish or Mid BB? Can't tell for sure from the photos.
Oh and is that the stock paint or was it painted over?
11/2/2015 6:05 AM
Email Eastern with the numbers stamped into the frame on the bottom where the crank goes through (bottom of the bottom bracket) and they will tell you.
11/2/2015 1:52 PM
What's the serial number? And is it a Spanish or Mid BB? Can't tell for ...more
i had it powder coated and the bottom bracket is mid also the serial is k7kyoo5359
11/2/2015 6:56 PM
Looks to be from around 2008-9 to me. It has welded gyro ...more
what is the email for eastern
11/2/2015 7:05 PM
What was the original color do you know?
11/2/2015 7:15 PM
it was a kinda off white.
11/2/2015 8:17 PM
You sure that's a mid bb? I looked and looked, but Eastern used Spanish on all their old bikes and the welded on gyro tabs suggests it's an older model.
Closest thing to what you have that I could find is it might be a 2007 Eastern Element since that year didn't have a cutout in the seat tube, but it was a Spanish BB and I have no idea what the TT length is.
Try emailing Eastern with the serial number, give em a couple days cause they're probably busy getting their company started back up again
This is their customer service email
customerservice@easternbikes.com
11/2/2015 8:35 PM
A guy on pinkbike said the 2007 eastern elements have a 20.75 tt
11/3/2015 6:11 PM
sundaybmxRR wrote:
You sure that's a mid bb? I looked and looked, but Eastern used Spanish on all their old bikes and the welded on gyro tabs ...more
my bad its a spanish. i was being told by a few friends it looks like a growler because it has the seat clamp cut out and the top of the seat tube is cut at an angle and i remeasured the tt and it came out to 20.but it doesn't make sense because the growlers have removable tabs for the gyro and the brake tabs.The bearings are a little bit smaller then the round spoke wrench i was wrong the bearings i have are the spanish.
11/3/2015 6:18 PM
my bad its a spanish. i was being told by a few friends it looks like a growler because it has the seat clamp cut out and the ...more
Growler has removable brake hardware so it's not that.
I still think it's an Element but can't be positive since I don't think their top tubes came that small.
How are you measuring the TT length? It goes from center of the head tube to center of the seat tube
11/5/2015 11:53 AM
I had a 2008 frame with the welded gyro tabs and it had a mid BB.
IG: therealclintvessey
{\_/}
