female hub stuck bolt
1/4/2014 7:54 PM
the non dive side will not come loose how do i fix that ???????
1/4/2014 8:02 PM
tighten the drive side bolt to your dropout and crank the fuck out of the non drive side loosening it
1/4/2014 8:14 PM
did not work !!!!!!!
1/4/2014 8:16 PM
That's weird... hmm spray WD 40 on it? Maybe thatll loosen it.
1/4/2014 8:19 PM
it a new wheel ody quad hub
1/4/2014 8:25 PM
Did you grease the bolts before putting the wheel on?
1/4/2014 8:26 PM
Tighten the other side that isnt that way. Then try to tighten that bolt that is stuck. If that doesnt work try to loosen it again.
1/4/2014 8:32 PM
it is Tighten i got it that way it will not loosein
1/4/2014 8:47 PM
help ????????
1/4/2014 8:52 PM
how are you not able to loosen it? get a breaker bar or something to gain leverage with, and take the correct sized socket to it and loosen it
1/4/2014 8:54 PM
the dive side will loosen
1/4/2014 9:06 PM
then tighten that even tighter.
actually take the drive side bolt out & look into the center axle, is there an allen key broach in there? if there is, you could use it to hold the axle while you loosen the other side
1/4/2014 9:08 PM
did not work
1/4/2014 9:10 PM
You might have cross threaded something or seized it. spray a shit ton of WD-40 in through the dropout to the bolt, let it sit, then try. if all else fails take it to a shop.
wtf did you tighten that with
1/4/2014 9:11 PM
i wil take it to a bike shop tomorrow
1/4/2014 11:35 PM
got it on bitches
8/5/2015 7:09 PM
How?? I have the same rim and the same problem.
8/5/2015 9:27 PM
Yes.
YouTube
Instagram (@WillStockSucks)
