frame specs
12/30/2013 12:58 PM
i cant find the specs for the fit aitken s2 anywhere any help
Fuck BMX
12/30/2013 1:02 PM
bmxmuseum
12/30/2013 1:35 PM
I've got one. It has a 21"tt and uses standard headset and an American BB. It weighs somewhere a little over six pounds. I can measure the chain stay and seat tube if you need me to.
IG
@curtis_cantbmxwell
12/30/2013 4:20 PM
Couple people on bmxmuseum said it has an internal HS, 74.5 HTA, and 71 STA. Don't know about the BB height or chainstays.
12/30/2013 4:28 PM
from here
Mike Aitken Series 2
74.5° head angle/71° seat angle/13.75" chainstays
20", 20.5", 20.75", 21" T/T lengths available
True Temper premium-grade SuperTherm alloy steel tubing
Seatstay brake mounts
Laser-cut 4130 chromoly dropouts
Press fit bottom bracket (Mid)
Powdercoated finish
Made in USA
5 lb 10 oz
Compatible with integrated Campagnolo and FSA headsets
12/30/2013 6:02 PM
sundaybmxRR wrote:
from here
74.5 head angle/71 seat angle/13.75" chainstays
20", 20.5", 20.75", 21" T/T lengths available ...more
It's definitely not a mid. The bearings are in cups that press into the frame. The bearings are to big to fit into a mid frame with out the cups, is that called pro sized?
IG
@curtis_cantbmxwell
12/30/2013 6:04 PM
blaaaaaaaaa wrote:
It's definitely not a mid. The bearings are in cups that press into the frame. The bearings are to big to fit into a mid frame ...more
its mid im running a shadow mid bb
Fuck BMX
12/30/2013 6:09 PM
I'm pretty sure the S2 came in a lot of variations cause I know someone who had one & theirs was a standard headset with a Euro BB. Go on BMX Museum & search the S2, there's multiple variations for them
12/30/2013 7:14 PM
The S2i Frame came with Integrated/Mid. The Original Series 2 was a Press Fit Head Tube & US Bottom Bracket. As a few people mentioned, there are a few variations. I Know there was a Press Fit/US B.B option & right before the S3 was introduced there was an Integrated/Mid set up & part of Me thinks & I'm really not 100% on this one, But... I believe there was an Integrated/US B.B option too.
12/30/2013 7:35 PM
This is my s2 back when I had it built up. You can see the standard headset and if you look closely in the last pic you can see the American bb. http://www.vitalbmx.com/forums/Bike-Checks,27/Mean-people-suck,1289525
I am wondering why the bearings from my American BB don't fit a mid frame. Did American bearings used to be bigger or something?
IG
@curtis_cantbmxwell
12/30/2013 7:51 PM
blaaaaaaaaa wrote:
This is my s2 back when I had it built up. You can see the standard headset and if you look closely in the last pic you can ...more
Do you know the brand of your BB?
12/30/2013 8:12 PM
I might be way off, but there's 2 types of American BB's & one uses Mid BB bearings, the other uses a size slightly different, but both still press into a cup that is the correct size for that type of bearing.
12/30/2013 8:53 PM
sundaybmxRR wrote:
I might be way off, but there's 2 types of American BB's & one uses Mid BB bearings, the other uses a size slightly ...more
That would make sense I guess. I just thought that American bb bearings could always be popped out and used in a mid frame.
IG
@curtis_cantbmxwell
