grind help
6/20/2008 4:49 PM
I'm learning double peg grinds and I'm grinding on the left side. The only thing to grind at the moment is a box at the skatepark. If i lean too far left the pegs dig in and i stop instantly, if i try to level the bike out, i fall right, how can I fix this? any suggestions will be appreciated.
Fear is only as strong as you let it be.
6/20/2008 5:26 PM
Edited Date/Time: 4/14/2016 4:26 PM
lean back to keep the weight on the back peg instead of the front so you dont dig in and just try to keep the bars and your weight steady. moving your knees back and forth to find your balance can help too. and how fast are you going at it? going with a good amount of speed makes balancing easier.
TBC represent
6/20/2008 5:30 PM
make sure u land evenly because if u land with ur front peg first u wont slide well and u will stop and if u go a little faster than normaly than it might help u balance more
that shit is retarded
6/20/2008 6:47 PM
Thanks alot, the grinds went soooo much better. With the increase in speed and leaning back I was able to grind the whole thing on the first try. by the tenth time it came pretty natural and started feeling better, thanks again.w00t
