head tube on frame
8/9/2012 9:57 AM
where the head set bearings sit...the head tube has to be a perfect circle correct??
i have bought a fit frame and i just checked the headtube..if thats the correct term..haha
and its off ..heres a pic..
i measured horizontal and vertical.. its off Like 1mm............. IS THIS NORMAL???
refs: nshs2010...kroller...
8/9/2012 10:03 AM
1mm shouldn't be a huge deal
8/9/2012 10:10 AM
well i measure real careful..and its a hair off..
but when i put bearing in ..i can rockk it back and forth a lil bit..
8/9/2012 10:11 AM
ok..should i put a lil grease around the metal and where bearing sits..??
8/9/2012 10:33 AM
yer put the headset in and build up your bike and if its still runs bad contact fit
parkrat.
8/9/2012 10:36 AM
Edited Date/Time: 8/9/2012 10:37 AM
sounds warped, could have been from using shitty bearings in the raceway. 1mm won't be too bad but you'll go through bearings a lot faster, just get some decent sealed bearings and ride, you won't even notice it and with only a 1mm difference the bearings should still last a year or so. If it bothers you that much a machine shop could round it back out, not sure on a price, all depends on who you use.
8/9/2012 10:49 AM
ok...well yea the bottom part seems tight...top not as tight..well i might try it..if not ill just sell it..haha..bought it for no reason i guess..dam!!
8/9/2012 10:54 AM
is that frame brand new?
parkrat.
8/9/2012 10:56 AM
don't sell it knowing it's fucked up, that's just bad karma
8/9/2012 10:58 AM
according to ebay..yes..haha..
i know man..but i wont sell for same price..ill go way cheaper...i dont scam...
8/9/2012 11:07 AM
if you wanna sell it for cheap lemme know, but honestly i'd just keep it and use it, i'm telling you that a set of sealed bearings will work just fine, 1mm isn't too bad.
8/9/2012 11:09 AM
well it less than 1mm is big..lol..i carefully measured it like i said..its like a hair..but enough to rock...bottom seems perfect and bearing goes in tight..
8/9/2012 11:10 AM
text me with offer..ill tell you how much i paid... 530 519 4063
8/9/2012 11:32 AM
it's a frame from the 2011 eddie signature complete.
8/9/2012 11:43 AM
alright i'll text you in a little bit, i'm about to head to Texas to pick up a DSLR.
8/9/2012 1:25 PM
ususally one may get an ovalized head tube by running their headset too loose for a while when riding hard but theres no reason why a new frame should be like that
REFSREFS: Four, agfracing, bmx4life121303, Austin_Read, the balt, handlebar-to-face, Murtaugh, killjonken, Bmx&volkswagens, TCbmx(x2), spikez5, A08, SuperstarDK, blizzbikes, ecuadevil, BMX4Lyfee, Kroller, 2283kdogg, ShadowBmx1995, WeAreFucked, killedglamour, Showtime402, ScramHype, Prophet, 2wheelguy, ugot2dewitt, Sancheezz, tomdon five16-207-nine457
8/9/2012 1:33 PM
i see...and i texted you man..
8/9/2012 4:15 PM
Never knew of these things.. I don't even check to be honest. All the bikes I've put together had the bearings sit flush and work fine.
