headset installation question.
10/2/2011 8:27 PM
After you have tightened your compression bolt then your pinch bolts and everythings all good, is it alrght to give your compression bolt abit of a tighten afterwards? It cant damage the headset can it since the pinch bolts are already done up?
10/2/2011 8:29 PM
It's all good.
10/2/2011 8:32 PM
I wouldn't recommend it, since your pinch bolts are tight, the stem won't move and this could cause your compression bolt to snap if you try to tighten it. If the headset is tight, leave it be, if not, start all over.
