headsets sti
7/22/2014 7:55 PM
if I have the standard to integrated headset on my bike can I buy a campy spec headset and put it in the bearing cups?
7/22/2014 8:13 PM
you should be able too its the same spec bearings... Say, could you do me a favor, If you have an STI, can you measure the sti for me? the cup diameter specifically.
"The D.O.P.S. System"
DK, Odyssey, Profile, Shadow.
check out my bike check
@ethanbrackett
7/22/2014 8:15 PM
dkTechEthan wrote:
you should be able too its the same spec bearings... Say, could you do me a favor, If you have an STI, can you measure the sti ...more
I don't have them yet, there on the way right now. but the inside or outside diameter?
7/22/2014 8:19 PM
outter, I want to try and find a rotor that could fit over it, if possible, If not i might just end up casting one myself.
@ethanbrackett
7/22/2014 9:39 PM
Yep just did it.. You just need the cups I got a demo one and you can do the same with bottom bracket also!
Bicycle motor-cross Motor bicycle-cross Bicycle cross-motor Motor cross-bicycle!
7/22/2014 9:43 PM
Hey Ethan every rotor fits over it. Its not any larger diameter wise than your average headset...I have it and have used a basic rotor from odyssey on it
7/22/2014 11:02 PM
KrisnerBMX wrote:
Hey Ethan every rotor fits over it. Its not any larger diameter wise than your average headset...I have it and have used a ...more
wait, so I can run an Odyssey G3 upper and lower plate, and the rotor, then eventually switch over to a GTX-S and run a Mechanic STI headset aswell?
If so, I'm ordering it tonight!
@ethanbrackett
8/12/2014 8:14 PM
dkTechEthan wrote:
wait, so I can run an Odyssey G3 upper and lower plate, and the rotor, then eventually switch over to a GTX-S and run a ...more
I know this thread is old but do not buy the sti headset. I broke two headset bearings because they don't fit into the cups the right way.
8/12/2014 8:17 PM
Jonathan Pfadt wrote:
I know this thread is old but do not buy the sti headset. I broke two headset bearings because they don't fit into the cups ...more
yeah im going to call that an isolated incident or user error
i had multiple friends have no problems with them
8/12/2014 8:20 PM
user error.
What bearings did you use? and are you sure you installed them properly?
8/13/2014 4:11 AM
user error. I have had mine for over a year with absolutely no problems.
8/13/2014 10:09 AM
Got the verde neo STI headset in my 2002 barcode and had no problems atall.
I don't think you know how to install something that requires thinking.
