can i keep the same hub and spokes and change my rim without needing to buy new spokes?
you can if the rim is needs the same spokes as the other. What hub and rim were you using before? and which one are you switchen too?
BRANDON_90 wrote:you can if the rim is needs the same spokes as the other. What hub and rim were you using before? and which one are you ...more
Second this. Providing the two rims have the same diameter you will be fine.
Latest edit (Check it out) | Anything With Two Wheels Goes!!
"Fuck it and Huck it" -Tomdon
Not just diameter, they need the same ERD.
Two rims could have the same Diameter, but different ERD's.
Best bet, go to your local shop and find out for sure, or call Dan's or something.
Sharpy wrote:Second this. Providing the two rims have the same diameter you will be fine.
dave lawrence wrote:Not just diameter, they need the same ERD.
Best bet, go to your ...more
Is that like the inside of the rim or something?
effective rim diameter
