Help please!!
1/6/2014 6:08 AM
ive got the odyssey aitken k-lyte folding tyre and i cant put them on my rims without having high and low spots. is their an easy way off making the tyre even around the rim?
1/6/2014 6:46 AM
What do you mean exactly by high and low spots?
-HardBMX_Tim
1/6/2014 6:59 AM
the tire tire wall is higher in some places and barely visible in others
1/6/2014 7:08 AM
Inflate your tire.
1/6/2014 7:16 AM
ive done that but it doesnt change a thing and when you ride it spins unevenly
1/6/2014 7:25 AM
basically I remounted the tire onto my rim about 10 times today and keep winding up with low/high spots where the bead is either very low (concealed from view by rim sidewall) or too high - this looks like a really bad series of vertical hops when you spin the wheel.
1/6/2014 7:30 AM
Sounds like you might have a bad tire. Return it for a different one. At least you didn't bash Odyssey for finding one bad tire.
1/6/2014 7:31 AM
ive got two and theyre both exactly the same
1/6/2014 7:36 AM
OMG Odyssey sucks!!!
1/6/2014 7:38 AM
i think ive thrown away the packaging too
1/6/2014 7:38 AM
Post some pics.
1/6/2014 7:52 AM
Sounds like the bead is not seated well. Let the air out and try spraying a little windex on the bead or even some rubbing alcohol (dries fast), and then airing it back up. Sometimes a little moisture will help it slip into place.
1/6/2014 7:53 AM
1/6/2014 7:54 AM
1/6/2014 7:55 AM
cheers dave gonna try it now
1/6/2014 8:02 AM
i havent got any windex or alcohol in my house would any household cleaning spray work
1/6/2014 8:03 AM
Wow. That's bad. I've not had a problem like that before.
1/6/2014 8:05 AM
dave lawrence wrote:
Sounds like the bead is not seated well. Let the air out and try spraying a little windex on the bead or even some rubbing ...more
water with liquid soap works too!
1/6/2014 8:33 AM
That's really weird I've never seen that before. Are you rims ok? Is the inner tube twisted?
I think maybe tho them tires are just fucked, not sure.
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
1/6/2014 9:59 AM
the rims are fine and i dont think the tubes are twisted
