how do i no what rear cone nut to get??
7/20/2013 3:40 AM
i was tightening my chain and when i tightened the lock nuts back up my driver was completely locked up so i took the cone nut off and found out that it was stripped and was pushing against the bearing and locking it all up. My bike is a haro 500.1 and the hub is no particular brand so I'm not sure what cone nut will work??
7/20/2013 6:10 AM
If it's generic, it's usually pretty hard to find hub hardware unless it's like Odyssey or Joytech stuff.
7/20/2013 2:04 PM
Edited Date/Time: 7/20/2013 2:08 PM
Not sure where you'd get one. but when my cranks spindle was stripped i used a tap to fix te threads. if its not too bad id try using that. If that doesn't work, check your local bike shop they might have a spare one that'd fit. If the hub is loose ball bearings then most other cone nuts for loose bearings should fit because they're almost all the same.
