hub driver won't move at all
10/8/2013 2:17 AM
yes, I used the search bar. but I have an unsealed Hub and the driver won't spin at all. I even took out the axle and it still won't move. I also found some broken balls in the driver side like they were clean in half. please don't say get sealed hubs. I would If I had the money
10/8/2013 2:18 AM
and how do I take off this driver Photo
10/8/2013 2:29 AM
Normally it would come out with the axle, but i take it that if it cant spin and you cant pull it out then it probably stuck their, try tap it through from the other side.
Latest edit (Check it out) | Anything With Two Wheels Goes!!
"Fuck it and Huck it" -Tomdon
10/8/2013 2:34 AM
Sharpy wrote:
Normally it would come out with the axle, but i take it that if it cant spin and you cant pull it out then it probably stuck ...more
I've taken it apart before while it was working and it didn't come out with the axle, I'll give pictures of both sides so you can look at it Photo
10/8/2013 6:08 AM
I would bet it is similar to the Redline unsealed 9t, where you need a large allen wrench in the non drive side to spin it out, if I recall correctly it is a 10, 11, or 12.
10/8/2013 1:32 PM
dave lawrence wrote:
I would bet it is similar to the Redline unsealed 9t, where you need a large allen wrench in the non drive side to spin it ...more
So I see a place where it might go in. so do I just turn it left and it's like a compression system?
10/8/2013 2:01 PM
Buy a sealed hub.
10/8/2013 2:29 PM
HardBMX_Tim wrote:
Buy a sealed hub.
yeah, I have one on my primary but I'm getting my cousin into bmx and he's using my secondary
