im not a tard but i need fc help
7/10/2011 1:51 AM
i need to know what the driver bearing size is for the original KHE reverse hub is and its not the same as the ACB one so please dont send me a link to that
iv looked but i cant find it online and it doesnt say on the bearing soooo im lost
also im wondering if theres any place to get the parts for the pieces that hold the clutch on the axel
so basicly is there any place to buy fc parts without buying a whole new driver or axel
thanks in advance for the help to everyone
I HAVE A PAIR OF BLACK ODDY 7KAS I WILL TRADE BOTH FOR A PAIR OF SUN ENVYS (MUST BE FRONT AND REAR MATCHING SET) ANY COLOR
7/10/2011 2:33 AM
7/10/2011 6:29 AM
Edited Date/Time: 7/10/2011 6:30 AM
7/10/2011 6:39 AM
Local shop that uses QBP as a distributor, and you can find a lot of those parts. You may just need to bite the bullet and get a new axle.
7/10/2011 6:43 AM
Direct from the KHE website
inner Diameter (d), outer Diameter (D), wide (w)
Bearing size of the KHE Geisha, Reverse and MTB Geisha
- one piece of 6202-2RS (non driver side bearing) d = 15mm, D = 35mm, w = 11mm
- one piece of 6905-2RS (driver side bearing) d = 25, D = 42mm, w = 9mm
- two pieces of 6802-2RS (driver bearings) d = 15mm, D = 24mm, w = 5mm
Bearing size for the KHE Hure hub
7/11/2011 3:30 PM
thanks i found that now i guess i just need2 look a little harder next timesmile
