what can i use instead of grip glue as grip glue????
what?
Dave Lawrence: "Pot is like the lazy retarded cousin of drugs. No one cares, they just give him a ball and he's happy on his own."
Refs: Fede/bmx1, Nmyersomg, Meowmoo68
hair spray with a screw diver dont cut your grip open
get chechup with a a paper towl and wipe it on it it will work
nothing, just slide them on without anything on them. you gotta twist and push a lot put mine never move
FEEL ME!!-Nigel Sylvester
hairspray or just take it off wipe it completely clean then put a very very tiny bit of water so it can slip on then spin them a little n leave it for a lil while theyll dry on
tryed it
wait over night for some reason it made it worse
just put a little spit in them and slide them on. wait about fifteen minutes and they'll be good
alcohol, but not drink alcohol lol, the one to desinfect stuff
when it evaporates your grips will not move at all
If u have an air gun attatchment for yo air compressor use that when u have a quarter of tv grip on put the nozzle in the end and pull the trigger it will make the grip bigger so it can go on and when u take the nozzle out it will go small again mine never move
use some zip ties, put em underneath the grips, like a bunch. and let the plastic of the zip ties slide on to the bars, seems weird but it works. try google it on ride bmx web page, it was on there.
go high
get chechup with a a paper towl and wipe it on it it will workadammm wrote:
tryed it
Did it freeze overnight? Try taking grips off, drink a can of mountain dew or coke, then spit in the grip, let the spit dribble thru the whole grip, and then slide it on... The spit will lubricate it enough to get it on there, but the Dew will make it sticky, and when it dries, it will hold on pretty well.
i have used spray paint and it works pretty well
and also the air trick works good.
i do this on my quad when i put grips on and they dont come off so its bound to work on a bike lol
hair spray, or soap, or spit and a little bit of elbow grease are my favorites
cheers to fucking your bike up....fixing it and rinse wash repeat
use baby oil to get your grips on and off, and once that stuff dries all the way your grips never move, ive been usuing it for years
My refs ?... Nigga just ask about me
wax and grease remover thats realys good i used it they slid on very quikly but it drys so quick ya got to get them on with in like 10 secs but get them on and its very hard to get them off! and if ya use that it cleans the bars and grips of any oil so they go on and stay on!
need new signature (Y)
^^^^^ best way to grips on ever is the zip tie trick no throtle and no waiting for hairspray or lube to dry its soo fast and eazy!
ive never had a grip slip. just but anything on the bars and inside of the grip and slide the grip on. wait 10 minutes and ride.
if you get new grips, just use an air compressor with a needle(like when use to fill a basketball) and push the air betwwen the grips and the bars. once on, they wont move as long as your bars are clean under the grips.
umm just boil some water stick your grips in the boiling water take em out after like 10 min they should feel soft stick em on your bars lock down on them with your hands in your normal riding position they should kind of form like ure hands and stick on your bars or just get wd-40 spray the grips while their on the bars light em after the flame goes off grip onto them like normal ridiing position with gloves so you dont get burnt if their hot those 2 should do the trick
Children Bmx
air compressor
http://teamlmnop.blogspot.com/
www.msgpanda.blogspot.com
Flickr
team Mango PRO rider
