Is there a difference between the flatland version and the regular because dans only has the flatland version
Quote
Refs:
ac~handley -les.cheek - the_bmxist -Skids007(x4) - Roqfan - jared42069 - Bmxnick2511
Refs:
The axle is small. Its like the 3/8s female so unless you are confident that you wouldnt break the axle, and sure you can find 14mm adapters to fit your frame, then go for it!
