little help
12/18/2013 11:00 AM
So maybe I'm just retarded but are the s&m tuffman and redneck xlt anodized? i just soaked them for like half an hour in oven cleaner and nothing happened.
Should i just use paint stripper or just a different kindof oven cleaner?
Murica bike check
12/18/2013 11:07 AM
I thought you had to heat it first
I could be wrong though
12/18/2013 11:44 AM
What color is it?
Oven cleaner you just spray on it for about 5 minutes the first time, then rub with a cloth all over. Then spray it again and let sit for 2-3 minutes, then rub, and repeat until it's raw. I rawed my G-Sport rims that way & it took some time (they were hard anodized black, not sure if that's why)
You DON'T want to let the oven cleaner soak it too long though, that can cause it to pit the aluminum
12/18/2013 12:03 PM
Both are black.
That's what i was doing i sprayed it amd soaked it for about 10 minutes the first time then cleaned it off and did it again two more times but none of it came off so i just stopped so i didn't mess up the aluminum maybe i just got shitty oven cleaner or something.
Would it work if i sanded the parts down first alittle then soak them?
Murica bike check
12/18/2013 12:19 PM
They're definitely anodized so idk, are you using this kind? It's what I used. It did take about 2 sprays & rub downs to start seeing results though
12/18/2013 12:23 PM
Make sure the oven cleaner has sodium hydroxide in it
12/18/2013 1:35 PM
@Sunday yeah it was easy off but not the heavy duty one that might be why.
@Thompson im not sure if it had that I'll look for it when i buy more oven cleaner though
Murica bike check
