marauder
10/22/2008 7:57 PM
Edited Date/Time: 10/22/2008 7:59 PM
im gonna get the marauder thnks micmack
but the breakless if u change handlbars can u get brakes on it cause some bikes do that im not sure of the maruader so if u get a different bar can u add brakes?
______________________________________________________
Brakeless
10/22/2008 8:02 PM
hey u got aim man? i got a few things to say about the bike
10/22/2008 8:04 PM
yea
m0nkey mAnure
theres a zero in monkey not o
Brakeless
10/22/2008 8:05 PM
you have to have calliper brakes on the bl version
10/22/2008 8:05 PM
which are not good so ive heard
my general understanding of that style of break is meant for "slowing down" its not NEARLY as good of a break as what u would get with an actual break. so ive heard
10/22/2008 8:09 PM
Edited Date/Time: 4/14/2016 5:31 PM
Single pivot side-pull caliper brakes consist of two curved arms that cross at a pivot above the wheel and hold the brake pads on opposite sides of the rim. These arms have extensions on one side, one attached to the cable, the other to the cable housing. When the brake lever is squeezed, the arms move together and the brake pads squeeze the rim. These brakes are simple and effective for relatively narrow tires, but have serious disadvantages if made big enough to fit wide tires. Low-quality varieties also tend to rotate to one side during actuation and to stay there, so that one brake pad continually rubs the rim even when the brake is released. These brakes are now used on inexpensive bikes; before the introduction of dual-pivot caliper brakes they were used on all types of road bikes.
does this sum up the breaks that you could put on the BL version?
10/22/2008 8:10 PM
pretty much caliper brakes are heavy and suck ass
