my antigram skips out the box
2/22/2015 2:47 PM
its been on my bike for about 2months now and its still skipping. what the fuck.
i did put a couple thin sparse dabs of lithium grease in the the hubshell but i dont see that causing the problem. i used to dump way more grease in my ratchet and never had this problem
help, please
wallride a bus everyday
2/22/2015 2:47 PM
ufkc, ghost pedaling, i meant it has been ghost pedaling
2/22/2015 3:07 PM
have you tried to warranty it yet
2/22/2015 3:11 PM
Testimony and apologies
instagram
old edit
2/22/2015 5:08 PM
id like to avoid relacing a wheel and what the fuck is that memething supposed to mean
2/22/2015 5:13 PM
The meme is because that idiot has one little problem with his antigram hub and rather than work with it to fix it he just posts online and bitches nonstop about it.
Now, is your hub skipping or ghost pedaling? Which one?
If it's ghost pedaling, you're probably making the axle bolts too tight, or something could be machined wrong
2/22/2015 7:16 PM
sundaybmxRR wrote:
The meme is because that idiot has one little problem with his antigram hub and rather than work with it to fix it he just ...more
This can happen to if you mashed up your driver at all from grinding. You may want to take a look inside the the hub shell and see if there's any flat spots from impacts. Usually you can fix those up.
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
2/22/2015 7:30 PM
ghost pedaling. should be no grind damage. ill take it apart and look for flatspots or something
2/22/2015 7:46 PM
Maybe try cleaning it out as well and replacing the grease with a light oil.
Chris
2/23/2015 9:31 AM
definately this. clean the grease out and used a little bit of that 3-1 oil, or silicone dry lube. Grease doen't work very well in casettes at all.
2/23/2015 9:48 AM
as seen above because douche bags on here haha
contact Odyssey about it
instagram
old edit
2/23/2015 9:49 AM
avoid doing anything to it before getting ahold of Odyssey if ita ghost pedaling something is wrong mine didn't even do that
instagram
old edit
2/24/2015 9:03 AM
Is it in the dropout crooked? Chain might be too tight.
2/24/2015 2:52 PM
My antigram ghost pedaled out of the box as well. It just takes awhile for the springs to break in. What I did to fix it was bend the spring a little to make them softer since they are super stiff out of the box. Now it's fine.
2/24/2015 9:07 PM
Chain can be too tight
Cones can be too tight
damaged hub shell
Chain is shitty with frozen links
can be many things, pictures would help
2/24/2015 11:44 PM
Just a question, is ghost pedaling bad? Mine hub does because the chain is tight, but it never skips or gets stuck (like engaged so I can't coast).
