my sprocket is moving back and front when i pedal and my chain loosens and tightens i need help :/ !!
You havent got the correct top hat washer on the inside of the sprocket. Take it all off, pop the top hat washer in & rebuild the crank setup & you're good to go.
BMX_Forever wrote:You need a spacer in your sprocket.
This.
You did something wrong.
yup need a spacer
Murica bike check
This happens and is still happening to my bike, the guys at my bike shop said that it is because the sprocket is not a prefect circle, and that all sprockets are slightly ovalized, so idk mine does it really bad to the point that the Cain is tight at one point, and a half crank later it is sitting afew mm's above the frame
Purple bike wrote:This happens and is still happening to my bike, the guys at my bike shop said that it is because the sprocket is not a prefect ...more
Yeah that happens to me too, but from what he said it sounds like the whole sprocket is moving, which would suggest a lack of a Spacer.
BMX_Forever wrote:Yeah that happens to me too, but from what he said it sounds like the whole sprocket is moving, which would suggest a lack of ...more
Ohh lol my bad
Purple bike wrote:Ohh lol my bad
Haha not saying you're wrong, just putting it out there.
Is the chain going tight to loose normal? I always thought I just had a bent sprockey
Anderson IN
loudsilence96 wrote:Is the chain going tight to loose normal? I always thought I just had a bent sprockey
I learned from my lbs that all sprockets are slightly oval shaped so tight spots are normal, but I'm not so sure because my old sprocket had no tight spot what so ever
I'm missing like 5-6 spokes in my front rim, I really need to replace them. Think I should stop riding till I get new ones?
Anderson IN
Spacer, you should noticed this when you installed it
loudsilence96 wrote:I'm missing like 5-6 spokes in my front rim, I really need to replace them. Think I should stop riding till I get new ones?
yup just tighten the others or just go spend 6 bucks and buy some
