my tire has a hole
5/3/2021 12:07 PM
so i had puncture for 3 sesh in a row this week (each time on my way to the skatepark)
lately i tried to hop a big ledge and had a snakebite that left my tire with a hole in it so i suspect it for being the reason to those puncture's
its a new tire, maybe i'll be able to fix it with a mushroom like being used on car wheels?
if yes, which size mushroom will fit ?
5/3/2021 12:24 PM
Superglue the hole closed. Then cut a chunk of an old innertube about 100mm long and superglue it across the hole on the inside of the tyre.
5/4/2021 2:40 AM
p1p1092 wrote:
Superglue the hole closed. Then cut a chunk of an old innertube about 100mm long and superglue it across the hole on the ...more
I didn't have anything you said, so I just put a puncture patch on the inside and injected some kind of roof sealant on the outside. (when it drys it acts like rubber)
hopefully it'll work
5/4/2021 3:17 AM
Duct tape, thin card, more duct tape.
There's no permanent fix though. Get a new tyre
5/4/2021 4:07 AM
If putting a card is possible then why not put those?
it is a new one so ill try to get few more months with it
5/4/2021 4:46 AM
Edited Date/Time: 5/4/2021 4:47 AM
^Those are designed for car tires, for small holes. Like nail holes, and they are not a permanent fix. Also car tires tend to not use innertubes. I have used those for nail flats on a car.
For a hole in the tire-old innertube and some glue. A paper US Dollar (or similar material) in there helps too. Basically any material that is reasonably tear resistant that would prevent your tube from sticking out. Park tool has a "tire boot"-a flexible rubber patch that sticks on inside the tire to stop a tube from coming out. Works as a temp fix until you can replace it.
A snakebite flat is two holes-usually caused by not enough air pressure. If your tires are low, air them up.
5/4/2021 7:44 AM
It's just another temporary fix, card and duct tape is cheaper. But you will need to replace your tyre no matter how you try to fix it
5/4/2021 8:04 AM
Those tyre worms aren't suitable for use with tubes at all, on any type of tyre...
They are however considered a permanent repair for bicycle tubeless setups.
5/4/2021 12:03 PM
Stick your dick in it, a hole is a hole.
YOU AVIN A LAUGH M8?
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
The Trailest Bike On Vital
5/11/2021 11:14 AM
Is that what you tell yourself every time Krooked is bent over in front of you?
5/11/2021 11:28 AM
That doesn’t happen nearly as often as I’d like.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
5/11/2021 1:53 PM
Edited Date/Time: 5/11/2021 2:15 PM
Start paying towards his college debt and it'll happen an awful lot more often. wink
5/13/2021 1:20 AM
lately i tried to hop a big ledge and ...more
Slime innertubes 😈
Speed, I am speed... -Lightning McQueen
Fuck money get bitches... I think?
