need help with 3peice crank
1/10/2014 5:18 PM
so I just bought a mirraco edit and a attack ltd bikes and the boths the cranks are loose I have no idea how to tighten them the guy said something about stick a screwdriver in the slot then turn the crank arm I tried that and no luck any thoughts?
1/10/2014 5:26 PM
Find a hex wrench that fits and then righty tighty lefty loosy
IG
@curtis_cantbmxwell
1/10/2014 5:29 PM
I'm gonna guess it has pinch bolts, so loosen the pinch bolts first (ones on top of the crank arm), then tighten the middle bolt, then tighten the pinch bolts again
1/10/2014 5:38 PM
im talking bout like the inside of the crank the arms are tight but you can wiggle the middle in and out
1/10/2014 5:40 PM
have you taken them off before?
maybe you need a spacer that isn't on there...
skooter... dont be a pussy
1/10/2014 5:42 PM
the Bottom bracket? pictures? I couldn't find much on the bikes, are they unsealed BBs or sealed?
1/10/2014 5:43 PM
I never took one apart b4 they were like that when I bought them I no how to tighten the arms and all that but the kid that I bought them from said u just have to tighten the middle idk I guess it could be a spacer issue
1/10/2014 5:46 PM
im kinda new to this so yea I think the bottom bracket and im not sure if there sealed or unsealed ima try to get pics now
1/10/2014 5:51 PM
1/10/2014 5:52 PM
both bikes have same issue
1/10/2014 5:53 PM
the first pic is the mirraco second is a attack limited
1/10/2014 5:55 PM
Needs spacers
IG
@curtis_cantbmxwell
1/10/2014 5:57 PM
first one needs more spacers, second one the BB needs tightened. best to take that one to a shop cause it's easy to fuck it up if you don't know what you're doing
1/10/2014 5:58 PM
blaaaaaaaaa wrote:
Needs spacers
so the mirraco in first pic needs spacers?
1/10/2014 6:00 PM
ok thank you guys for your help so I guess I can get the spacers the mirraco needs at the shop to?
1/10/2014 6:04 PM
o and one last ? do these bikes use a one eigth chain or a three thirty seconds sorry for the noob questions
1/10/2014 6:08 PM
Yes, and should be able to but if not, then I'm sure they have a bottom bracket you can buy that comes with the correct spacers. And it's usually 1/8"
1/10/2014 6:21 PM
awesome thanks
