need help with sprocket and cranks
1/4/2014 1:25 PM
hey guys,i was on danscomp and I noticed that some parts are not compatible with other parts.I want to get the odyssey thunderbolt cranks and a S&M L7 Spline-Drive Sprocket. For the bb for the thunderbolts I went with Shadow Conspiracy Corvus BB Kit 22mm mid.will these 3 parts be compatible for each other?if they aren't please suggest something that will be compatible with the cranks please. The cranks say that it needs a chainwheel but isn't that the same as a sprocket? also what is the difference between a spline drive and regular sprocket. and the difference between a socket drive and regular cranks. thanks
1/4/2014 1:34 PM
spline drive chainwheels work with spline drive cranks, cranks with 48 splines such as profile cranks. The thunderbolt cranks have a built on chainwheel/sprocket adapter you have to find a chainwheel with the 15/16 bore only. the socket drive cranks only work with socket drive chainwheels
brakeless maniac
1/4/2014 1:35 PM
so look for chainwheels with 15/16 bore and you with be fine!
brakeless maniac
1/4/2014 1:48 PM
whats the difference between a sprocket and chainwheel
1/4/2014 1:48 PM
I chose a fit ket sprocket for my thunderbolts.will that fit?
1/4/2014 1:50 PM
The sprocket and the chainwheel are the same thing in pretty sure.
1/4/2014 1:53 PM
sprocket and chainwheel is the same thing u can call it both. i have an odyssey mds chainwheel with my thunderbolts
brakeless maniac
1/4/2014 1:55 PM
ya the fit will work
brakeless maniac
1/4/2014 1:56 PM
thanks sooo much guys
1/4/2014 1:57 PM
go for the best setup - thunderbolt / c-512
