karsk wrote:
I suggest check out http://www.danscomp.com/ first. Get an idea of what frames/bikes you can get for your money. Most people will tell you it's just a matter of opinion. Check back through the old posts, many people have asked about bikes and frames.
Decide what size TT (top tube) you want, as you say your current one is too small. Go to a local shop and try out a few bikes, see what you like.
livin2sk805 wrote:
i dont really have a good local shop. Theres a profromance bicycle, they dont do much in the way of bmx, just carry bikes, and a agees which dosent have a huge selection. I really just want a frame that all the parts on the zone can go onto
Well check out Dan's comp. Get a feel for what you like as far as looks, what each frame has, etc.
I personally am a fan of WTP, Stolen, and Macneil. But some of those may be out of your price range.
What size is the TT on your Zone? Most (if not all) of your parts should swap to a new frame easily.
That said, you do need to check a few things:
-do you want gyro? or what type of brake set up are you wanting to run?
-axle size, do you need 3/8s or 14mm axles?
-BB size, is it American, Euro, Spanish, Midsize...?
-make sure that your gear ratio will fit the frame you are looking at (it should, but make sure)
-is the headset integrated?
Find a website, or if you have the info on your bike already, compare it with some frames you are interested in. But you will need the measurements and basic info to know if the swap is compatible.
Hope that helps.
I'm not ignorant, I'm just working on my senelity.
