painting
3/11/2015 8:40 PM
Will aircraft striiper/regular paint stripper remove weld marks on frames with a trans paint job?
3/11/2015 8:43 PM
Edited Date/Time: 3/11/2015 8:43 PM
Nope. What will remove the weld marks is using sandpaper or steel wool/copper scrubbers. Basically anything that scrapes/scours
3/11/2015 8:45 PM
tomdon wrote:
Nope. What will remove the weld marks is using sandpaper or steel wool/copper scrubbers. Basically anything that ...more
Thank you very much just what I needed smile
3/11/2015 8:57 PM
also if you want to like clear raw a frame would you use primer then clear coat or just clear coat?
3/11/2015 9:00 PM
Just clearcoat. Primer is like a paint. Youd have grey instead of raw lol.
3/11/2015 9:55 PM
They do make a clear primer.
(insert sig here)
3/11/2015 10:13 PM
Rustoleum gloss clear works great you can get it in flat too. They make it in regular or 2x coverage I personally use the 2x coverage and it works great. Make sure you keep around 10-12 inches from the part your spraying the clear coat on or it will run really easily and you will have to start over.
3/12/2015 2:34 PM
The weld marks MIGHT not be there, if it was heat treated. I had a frame that was that I rawed ONLY with paint stripper, and it was a dull gray, no weld burn.
