peg/droupout problem
11/20/2013 11:29 AM
hey guys I've had the shadow little ones pegs and their diameter is smaller which in turn shows more dropout I've bent the dropout on 2 other frames using these pegs any tips for guarding the dropout a bit more
cheers guys all help appreciated
11/20/2013 11:45 AM
get different pegs? if youre bending dropouts, pegs are only like 10 bucks, so compare that to the cost of a frame or the shittyness of having bent dropouts
11/20/2013 11:49 AM
yeah I need a set with a bigger diameter would you know of any I think the shadows are 34mm
11/20/2013 11:59 AM
Grind on only the pegs, get plastic sleeves for the pegs?
Get bigger pegs?
Pull the wheel further back in the dropouts?
11/20/2013 12:02 PM
If you are hitting your dropouts and bending them you have weak dropouts or are slamming down into your grinds. Try softening your landings into them? Maybe don't hop a foot higher than the ledge you are aiming for?
11/20/2013 12:05 PM
More info would help. Pics and what frames will help a lot
11/20/2013 12:14 PM
its subrosa noster as the dropouts on it are big it does stick out abit it alright for now and I have just ordered the plastic sleeves but just wondering if any one else had this problem
11/20/2013 12:28 PM
I would think a subrosa frame would almost be made for the little ones (subrosa and shadow are like sister companies). Plus I think majority of heavy peg riders use little ones and have no problems. I run them w/o sleeves and have no problems. Plus I'm fairly sure majority of pegs have the same diameter or only 2mm wider so its not that. Its either product or user error.
11/20/2013 12:34 PM
probably just Irelands lack of smooth objects to grind on lol hopefully these plastic covers help cheers anyways guys
11/20/2013 12:58 PM
Smooth or not that won't bend a dropout unless you slam down on them.
11/20/2013 4:02 PM
Most plastic sleeves or plastic pegs have a diameter bigger than 38mm.
38mm pegs that i know are LinoG, Animal MK3, Gsport Van pegs, odyssey jpeg lighter
( ͡° ͜ʖ ͡°)
(͡O╭͜ʖ╮͡O)
