quick querry
11/29/2013 12:36 AM
Yo guys, just wondering if the thread on a 14mm axle is a m16? Just need to check for my project smile
NEW Bike check
Raw Clips Edit
11/29/2013 8:11 AM
It's M14 if that's what you mean.
11/29/2013 8:48 AM
nice one, you know whether they just tap it or if they use a lathe?
NEW Bike check
Raw Clips Edit
11/29/2013 8:53 AM
No idea. Tapping it would be fine though.
11/29/2013 8:57 AM
good to know, it'll make it alot simpler, thanks, one less thing to worry about smile
NEW Bike check
Raw Clips Edit
11/29/2013 9:02 AM
Edited Date/Time: 11/29/2013 9:03 AM
Standard 14mm BMX Axles do have a 1mm thread size though, instead of 1.5 which is standard for 14mm in general.
11/29/2013 9:14 AM
so ill have to get different bolts?? and why the different size?
NEW Bike check
Raw Clips Edit
11/29/2013 9:35 AM
Wait is it male or female? You will need different nuts if you're going to tap it with a standard 14mm tap.
11/29/2013 10:41 AM
male, and thats what i was thinking, i could even make a nut with cnc for shits and giggles and tap that... or die or whatever.
NEW Bike check
Raw Clips Edit
11/29/2013 10:53 AM
EddiMundo wrote:
male, and thats what i was thinking, i could even make a nut with cnc for shits and giggles and tap that... or die or ...more
You could, I've done it before and it was relatively easy. (I made them as I have a Male front axle so I made some 3/8" nuts with a 17mm head).
11/30/2013 4:37 AM
BMX_Forever wrote:
You could, I've done it before and it was relatively easy. (I made them as I have a Male front axle so I made some 3/8" nuts ...more
did you use cnc to do it or did you do it manually on a machine?
NEW Bike check
Raw Clips Edit
11/30/2013 9:45 AM
I used a CNC mill.
12/1/2013 2:43 AM
alright. Thanks alot
NEW Bike check
Raw Clips Edit
