silent chains?
4/22/2013 7:05 PM
Need a silent chain, i aligned my sprocket and driver and it still makes noise to an extent. Not to serious it just sketches me out sometime.
Refs:
ac~handley -les.cheek - the_bmxist -Skids007(x4) - Roqfan - jared42069 - Bmxnick2511
4/22/2013 8:37 PM
Grease it. It shouldn't make sounds unless it's rusty af or it's not aligned properly.
4/22/2013 8:38 PM
Take it completely off the bike and soak it in motor oil or whatever for a couple minutes, and then take it out and wipe off all the excess oil/lube/thin grease.
4/22/2013 8:41 PM
do NOT do this. Grease is horrible for chains. Use fine oils, I use 3 in 1 oil for my chain at home but in my experiences, white lightening chain lube works best.
Also, oil it first, then wipe the chain down, then oil it again. This ensures you get most of whatever gunk is on the chain off and allows the oil to do its job better.
4/22/2013 8:43 PM
sundaybmxRR wrote:
do NOT do this. Grease is horrible for chains. Use fine oils, I use 3 in 1 oil for my chain at home but in my experiences, ...more
........ I always put white lithium grease on mine.... seems to extend it's life O_o
4/22/2013 8:43 PM
Grease, oil, all the same for me LOL jk
I was ging to say WD40
4/22/2013 8:49 PM
WD40's a degreaser, helps get the rust off too if his chain is rusty. I soaked my oldd chain in WD40 over night before and it took nearly all the gunk and shit in the chain off. You have to lube it up again with oil though, a lot of people think just spraying WD40 on a chain is considering lubing it up, but it does the exact opposite haha
4/22/2013 8:50 PM
idk anything about that grease haha
I use this stuff
4/22/2013 8:51 PM
sundaybmxRR wrote:
WD40's a degreaser, helps get the rust off too if his chain is rusty. I soaked my oldd chain in WD40 over night before and it ...more
I SUCK with bearings and that right? I was like,"I'm going to WD40 my headset" before I knew what it was.
LUCKILY I didn't have any......lessoned learned, hide the WD40 tongue
4/22/2013 8:53 PM
I use the one in a spray can. It's really loose like it's grease mixed with oil kinda. I spray a crapload of that into a ziplock bag and add some slicone oil and throw my chain in and shake that bitch like it's no tomorrow. Then I take it out and dry off everything as good as possible so it doesn't attract so much damn dirt and dust, rocks.. I hate that.. I might have to redo this soon cause my chain is starting to gunk up and rattle again.
4/22/2013 9:01 PM
I hardly lube my chains and never had premature wear on sprockets or drivers (my driver actually looks brand new) nor do I break chains much (actually broke it twice this week, but I was doing sprocket stalls and smashed a couple link, those were the ones that broke)
Idk maybe I just get really lucky everytime I change something in my drivetrain.
4/22/2013 9:12 PM
LUCKILY I didn't ...more
OH I can top that story easily.. before I knew how to work on a bike properly, I got a pair of stock Fit forks from a friend for super cheap cause my stock Haro forks were bent everywhere. I got the Fit ones on my bike but I forgot to put the bottom bearing race in, so when I tightened everything up.. it didn't spin very well.
I'm fairly positive that's why I joined Vital, I googled like bike problems or something to do with headsets and a page came up saying to grease everything up.
I thought vegetable oil you use to cook with was the same thing, so I put a bunch on a paper towel and lubed the fuck out of my steerer tube, the inside of my headtube, bearing seats & the bearings -_____________-
still didn't spin, later realized I was missing the bearing race and put that on along with vegetable oil still in there hahaha fuck.
4/22/2013 9:17 PM
I greased my chain... Im going to try to get it off now
Refs:
4/22/2013 9:23 PM
hey, i ran out of chain lube a long time ago, can i use bones speed cream? lol its a skateboard bearing lube
Jade Bike Check
Refs : ninjacat33 ; SuperstarDk ; ecuadevil ; xbikeascammer ;blizzbikes ; tcbmx ; mattjmuldoon@hotmail ;bmx ; Uoykcuf ; BrokenBmx, the balt; Pavimo; bmx-junkie; Fit.Team.Rider' tito24; trentydoo; brendan.magner.9 ;Scramhype ; Jonathan.Vargas ; jared42069; tomdon ; lifeofridden2200; howlerfbm
4/22/2013 9:33 PM
WD40. Get like an old tub of butter or something, clean that out and spray WD40 in there until it's at least high enough to cover your chain when you put it in there. Let it sit for a good while then pull it out and wipe it all off.
4/22/2013 9:39 PM
sundaybmxRR wrote:
WD40. Get like an old tub of butter or something, clean that out and spray WD40 in there until it's at least high enough to ...more
I just wiped it off and put it in an old oil container and shook it up lol, its alot better now, thanks guys
Refs:
4/22/2013 9:40 PM
It should be somewhat straight, ive used it before
Refs:
4/23/2013 12:23 PM
sundaybmxRR wrote:
OH I can top that story easily.. before I knew how to work on a bike properly, I got a pair of stock Fit forks from a friend ...more
On my MTB I Oiled up the Discs because they were a little rusty. Stupidest thing I've ever done Bike wise.
4/23/2013 1:49 PM
I only use WD40 to clean my bike.
Never used it for anything else rather than removing sticker glue from stuff.
4/23/2013 2:13 PM
Edited Date/Time: 4/23/2013 2:15 PM
I got some park tools lube im going to use on my chain and hub tonight
4/23/2013 2:21 PM
didnt read all the comments so this may have been mentioned but nickel plated chains are really quite. i have a sram chain that is quite and smooth and pretty cheap.
selling refs: see profile
Instagram
