spinning cranks
5/6/2009 5:17 PM
Stay Fit? More like Leave Fit!
5/6/2009 5:18 PM
i just got my custom built last night and the cranks are spinning when i take my feet off
and its a quality hub (odyssey v3 cassette 9 tooth)
is this normal?
5/6/2009 5:20 PM
yea that happens to me and i thinks its just the bearing, acually same hub as you 2
massholes 4 lyfe!
bstick
legendsx23
5/6/2009 5:21 PM
so its alright? or do i need to do something about it?
5/6/2009 5:23 PM
well i did a tailwhip really hard and it smashed the wheel and it has happend since
massholes 4 lyfe!
bstick
legendsx23
5/6/2009 5:26 PM
also try to losen your chain a little
massholes 4 lyfe!
bstick
legendsx23
5/6/2009 5:34 PM
k thanks
5/6/2009 6:17 PM
Edited Date/Time: 4/14/2016 7:40 PM
& proly grease yer driver
Out tha game
fork 4 sale odssey classic dirt
5/6/2009 6:44 PM
so it should go away?
5/6/2009 6:46 PM
yea it may just need to break in a little
ferthebirdz wrote: my pegs are called cranks..
5/6/2009 8:06 PM
This is just because of the pawl springs being "too strong" so that just the weight of the driver and chain is not enough to allow it to freewheel...if it freewheels fine when you're on the bike, don't worry too much about it...it should go away after it gets more broken in.
5/6/2009 8:24 PM
maybe u can tighten ur drive cuz i know the primo mixs never spin forward unless u pedal
5/6/2009 9:08 PM
Yes. Usually a tight chain is the culprit on something like that...when cassettes get old it happens too. Loosen your chain a bit, and tighten down your bottom bracket some more and that should put a stop to it.
5/7/2009 4:35 PM
i loosened my chain a bit and its still the same
hopefully it just needs to be broken in haha
thanks tho
5/8/2009 7:21 AM
loosin the ring on the paws
fuck brakes all they do is slow u down
5/8/2009 8:49 AM
Grease the driver. Tibug is possibly right on this one. The cassette may need to be broken it, just go pedal really fast a lot and coast.
5/8/2009 8:51 AM
no TIGHTEN YOUR CHAIN , then it wont spin
5/8/2009 10:45 AM
tighten your bb and chain
I <3 theamazingjack, dan, ressler, and dakota
