squeaky cranks
1/12/2016 7:54 PM
I have the haro zebra cranks which are pinch bolt and i went riding today i usually have earburds on but today i fortgot to recharge my mp3 player and what do you know my cranks squeak lile crazy and i dont know why, ive never had this problem with any pinch bolt cranks do you guys have had this problem? if so is there any fix?
1/12/2016 7:58 PM
Grease the splines and bolts and it should help , if not try cleaning up your BB and regreasing it.
1/12/2016 8:09 PM
Ride it till it explodes , the faster you ride the more tension the parts are squeeking will shut up , if you ride fast
Enough the squeeking
Should stop after a couple sessions
1/12/2016 10:27 PM
Almost positive it's your splines needing to be greased. Take your crank arms off, grease the splines, then put it back together correctly and see if the squeaking goes away.
1/13/2016 11:33 AM
sundaybmxRR wrote:
Almost positive it's your splines needing to be greased. Take your crank arms off, grease the splines, then put it back ...more
This.
Could also be something slightly loose.
